- Thread starter
- #101
pimpin81
- 524
- 0
- Dec 14, 2007
bellingham,
Washington
Are you going to do more testing on this ? Let us know what you come up with good or bad workaround for link. Also 1 thing to think about the 2ga and 2gb's effectually have different injector pulse signals the 2ga you have to switch the firing order right at the coilpack .and hit that setting in link or is that setting for the 2gb's ....
Also the 2ga's have a cam and crank sensor on the drivers side of the block however the 2gb has an optical sensor on the passenger side of the engine where the 1g cam angle sensor Hall effect sensor sits . Don't know if this could be part of the issue but it does have to do with how the timing is interpreted inside the ecu as well as the ignition and the injector pulse signals this was I believe a work around but can't be certain I am not a programmer or a very good tuner just throwing up some ideas.
Poppoff must have gotten drunk and in a hungover blur come on here wishing it was POSDSM how retro. Haven't seen that name since the 04 Evo came out and EVOm sucked the life out of many a DSM soul...
