Archer Fabrications
- 9,719
- 705
- May 9, 2011
Scottsdale,
Arizona
Oh. Thats what you meant. Well in my experience the answer is no then. All my idle,
and cruise conditions were tuned perfect by me upon arrival and i was expecting for them to rework everything since my global and dead time were off leaving me an over estamated boost est and VE( still have this problem but it runs well, just not accurate readings and has since been reworked 100% by me) the only thing i ended up paying 300 bucks for was a base timing check. 4 DA timing cells changed, and leaned the hell out on pump 92 from my 11.1:1 to 12:1 which aaron claimed he tunes all the pump gas evos to. Personally i did not get my moneys worth and did not trust the lean afrs he set me at.
The week before i was runnning 28psi on really retarded timing. But was not getting knock, and had good afrs.
i detuned it before i arrived thinking they would do a full do over so i put it to wastegate pressure. Mind you i lived 45
Mins north of seattle and this drive was 4 hrs one way with a 4AM wakeup. plus gas. They didnt do anything but 4 WOT pulls and then my car had to go Off the dyno for the next car.
Bullshit honestly....However i think their dsms run On link and not AEM.
They are also only going to do a good job tuning if THEY built your motor and know it through and through.
They HATE holsets, aaron slyly talked shit about them,
most likely because they are FP sponsored. But whatever still no reason to treat a tune differently.
Apparently they didn't like BC cams either. So basically. If they don't like your setup they will shaft you, if you spent all your money with them building your shit. They will give you a good tune. Honestly i think thats only the reason to keep The shop rep good. But it's not cool for all the DIY engine builders that have had many miles of high boost with no problems. It simply does not matter to them,
They didn't build it, they don't care how well its setup, They won't push your setup.
. i was not like the 99%others at all.
thats perfect too. I'd want a little more juice personally then a 30r could dish out.
