VivaLaOC
- 124
- 25
- Mar 16, 2021
La Grande,
Oregon
Well I searched around awhile on here for anyone with a similar problem but my specific search/problem hasn't gotten me anywhere so I'm posting a new thread. Will delete when solved.
98 GS-T starts just fine and was driving perfectly fine until yesterday. I was getting on it somewhat not over doing it by any means but I was moving my car because I moved recently and haven't driven my car in awhile so I wanted to have a little fun while I was moving it. Well to make the story shorter I'll say this, I was in 3rd gear about 40-50mph approaching a corner, clutch in and downshifting and Rev matching and thought I had gotten into gear, well as I was in neutral trying to make the turn and realized quickly I'd lost all power/input from the transmission. Checked all fluids everything and nothing was leaking or off anywhere that I could see, when I pressed the clutch in it wouldn't make any sound but as soon as I let off it was like someone putting metal on concrete and dragging it ever so slightly that it barley made sound. So it is kind of grinding but you'd never notice it if the car was still driving unless you were at a red light and barley heard it. That's how little noise it makes. Had to tow it back to my brother's house to try and evaluate it but I haven't got the chance to go back and look at it. I have a general idea of what it could be and these are my guesses.
Clutch
Input shaft
Broken axle
Throw out bearing
Bad connection to a solenoid
Broken shift fork.
I have decent mechanical knowledge so don't sugar coat anything, I appreciate and value any responses or suggestions. If you can't get ahold of me on here quickly dm me and I'll shoot you my phone number so i can understand a little more in depth by hearing someone explain it verbally. If it's a known issue and I'm just having a brain fast I'll absolutely delete the thread.
Thanks.
Clutch
Input shaft
Broken axle
Throw out bearing
Broken shift fork.
Thanks.
