starts after 3 trys
tagartz
Sep 25, 2009
poway, California
been reading different threads but no luck yet. i bought a 98 gst 3 months ago:hellyeah: just a few weeks ago had problem with starting. it will start after 3 tries.. p1105 code came up took a look at my fps connector looks fine tested resistance on the fps. then i went to my coolant temperature sensor look really old so i replaced it.. it fixed the starting problem:hellyeah: but now my fan does not turn on..:banghead:. so i put the old sensor back on... is there something im doing wrong? any help would be appreciated... tnx dsmers:hellyeah:
tested battery and sarter works fine.
replace the one with double wires.. when i replaced the sensor it fixed my starting problem. took only one click to get it started.. but my fan would not turn on so put the old sensor back. thinking i did something wrong.
