starting problem...possibly ecu
kanis
Nov 28, 2004
knox, Indiana
ok the car ran fine when i bought it, but very shortly, it started idleing very strangly..soon after the strange idle, it would die out and i had a very difficult time starting it...now my car wont start at all...it went from running fine, to running fine sometimes, to not starting at all...i get no check engine light, (tho havent checked wile it actually did run) and i ordered a flow chart, followed step by step, the flow chart said check voltage for injectors, if not 10 volts, check ad wire, im getting like 8 volts to the injectors and the voltage doesnt pluse like u think it would when u crank the engine...i have no clue what an ad wire is..also more information for the reader, my fuel pressure is 45psi, im getting spark air and compression..if i squirt gas directly into the intake the car will sputter and almost start, till vapors are gone...i checked my injectors and cleaned any corosion on them...my injectors simply are not opening up, i dont know if this is caused by ecu problem, or if it has something to do with an ad wire....iv check all my relays by step by step the way my chilton says...any information would be appreated...im out of ideas
