2G ECU Possibly?
240GTR
30
Sep 12, 2003
Yourtown, Montana
OK, I swapped a 93 EVO motor into a 96 GST, I wired it up just like RRE said to for the CAS, re-pin the ecu injector wires, swapped the 2 blue wires on the coil pack triangular plug. Now we crank it, and it idles and revs like crap, and I pull each injector plug and come to find out, the #1 injector is not firing. I checked each wire at the ecu, and I get 14.4 volts while the car is running and while the keys are on and not running the red wire which I assume comes from the resistor box is giving me 12.2 volts, but #1 injector still isn't firing. I swap #2 and #1 injector plugs around, and #1 fires now, #2 doesn't. Anyone have any ideas? ECU, wiring, resistor pack, anything somebody knows I can check?
I appreciate the help guys.
Thanks
J.D.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
