starting issues on 1g tsi awd
taberj47
Aug 5, 2011
martinsburg, West Virginia
ok so i went to start the car and the pump primes but the starter does nothing so i pulled the starter and took it to autozone and it passes all tests but guy said bearing are about shot but anywho i threw in a new mpi relay and i power washed all the grease off my motor and trans to actually look clean but going to reinstall the starter and see if maybe my wires are old but can a new mpi relay ### this or bad ecu?
well i fixed the starter she cranks now thank god and my pump is sending fuel but now its not starting so im thinking the plugs, spark plugs, or rotor cap is shot thats my next step hopefullly it fixes starting to get irritated LOL
Our DSM's (Turbo). Don't have (Rotor Cap).
They don't use Distributor, They use Coils.
Check if you have spark, Or check your Cooling Temperature Sensor.
You might disconnect it with out knowing.
If it is disconnect it, It will not Start.
Well, that's if your car was running good before you took out the starter.
If everything is good, then is time to fallow the Link that (fourgsixthree33) post before.
yeah srry i meant coil pack but yeah car ran great before the mpi relay shot on it and im going to throw in new spark plugs tomorrow and ### does the temperature
sensor plug look like and where is it???
ok guys if i could get some help i would greatly appreciate it well i pulled the coil pack off what a pain i might add and i didnt smell any burns or such. but im not getting any spark one thing im woundering can a bad ecu or bad cooling temp sensor cause a no spark??
