2G Starter/no crank issue
Rengar18
261
Jun 8, 2009
Lancaster, California
So for a few days my starter stopped working on two occasions. Both times I just jiggled/tighten the positive wire nut going on it and it started right up.
Happened again, jiggled/tightened it and still wont start so i went ahead and replaced the starter and same deal.
Voltage on battery is good reading around 12~ while trying to turn it. I've read it can be the starter relay gone bad? How would I go about testing it (its behind the radio next to the fuel pump relay right?) Heres some pictures of 3 the grounds I have on the car (except chassis to IM) and the positive wire going to the starter. The + wire looks a little beat up, could it be that? I can go ahead and cut that off and clamp on a bronze post like the ground I have there.
Thanks.
Also note i'm using a bolt from the main bearing cap for a starter bolt (with the ground on it)if that matters at all.
def try to jump the battery to starter to point to relay ALSO if you are measuring voltage when cranking if you aren't seeing a significant drop at the battery that can point to the relay as well (not allowing voltage to send starter
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
