Started my 7 bolt install
johnmarines
377
3
Jun 1, 2008
houston, Texas
Well today I removed my old 7 bolt that had a hole in the side of the bock. I have to say it was a job. The new rebuilt block is waiting for me in the garage. When I pulled off the drive shafts the tore at the boots I'm assuming I need need new shafts because I have no idea how to replace just the boot.
There is a special tool made for putting just the boot on, maybe a local shop has one and you could get them to put it on. By the way how did you get a hole in the block.
Well, it's quite very simple. First.. clean the cv joint to remove all the grease and then remove the snap ring at the end of the shaft. after that, you will be able to pull out the cv joint from the splines. Put the new boot on, then the cv joint and the snap ring.... refill with plenty of grease. replace the cv joint inner end, clamp the boot on and you're done.
I am asuming the hole came from the oil pump... it locked up. Thanks anteversion for the instructions on replacing the boots... I can cancel the order from the local parts store.. $70.00 bucks each compared to 10.00 for just the boot... no brainer.
Well here is the pieces of the "rod" and part of the piston... all I can say is WOW. Most of the pieces were siting on the bottom of my oil pan.
Well here is the engine/trans ready to go... just waiting for a break in the weather... its been raining off and on for the past week and 1/2
the bad weather finally took a break... I was able to finally get the motor back in... all thats left to do is button everything up :thumb:
I bought the block from a friend of mine here on this site.. and the head ..I had mine built at the local machine shop, they tested it for cracks, decked and installed new seals. Hopfully by sunday I can fire it up
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
