7 bolt pre install?
AWDforthewin
116
Feb 28, 2014
Springfield, Oregon
Swapping bad 7 bolt for a new 7 bolt. Gonna change oil and do some othe things..
What eould you recommend while the motor is out? Anything besides an oil change? And also when I put it in on the first start up any precautions I need to take or just plug in and start?
How many miles are on the engine that you are installing?[/QUOTE
Was said to be rebuilt when I bought it. And looks to be very clean outside making me believe it was even more however this engine will see an hx35 running low 20 lbs of boost and a good mod list behind it adding to around 400 awhp
I would pull the timing cover and verify that the timing belt is in good shape and everything in there is set properly. Also look for any possible oil leaks while it is out. Not too much other than that really.
Cool sounds good what kind of oil would you recommend I know a lot of guys run royal purple ?
