Imback
Freelancer
- 1,421
- 538
- Nov 8, 2006
Long island,
New York
You should post a pic of the final product and where the wastegate will sit before making more.
I was just making this because I've had the parts laying around for 4 years. What kind of wastegate is everyone using? I want to see what is the most common, and start with that. I'm not paying $350 for a wastegate.
I haven't done anything with it. Still need a wastegate. I don't even have a car to put it on right now. I do this stuff in my spare time. I can make them any style. I don't have the overhead the big shops have, so I don't have to charge as much for stuff like that, but I still have to make it worth the time and effort. They are time consuming.
Not bad!. Try using a #5 cup, and lay the cup right on the metal, "walking" the torch from side to side. Really? I just more spin the cup from side to side doing flanges, and couplings, it lays right in there. For the filler rod just lay it in there and don't take it out, I give just a small amount of pressure on my rod to keep it flowing with the puddle.
You do that you'll come out with the most beautiful hand weld without using a machine. I tig weld stainles all day long. Be surprised what you can come up with welding that stuff like I do. Hell att my company, I can practice purged pipe welds for a week if I wanted. Take your time, it'll look amazing. I run maybe 92 amps welding flanges, so for that thickness, maybe 84-86 amps?
I appreciate that your flange is matched to the oblong shape of the exhaust housing. Seems like all of the other tial o2 housings use flanges with a round passage which isn't doing anything for flow through there. I know that's not the limiting factor... but it's nice to see it done right.
Its a flange I got from Extreme Motorsports when I worked there. I don't know where they got them. The fixture pictured above is very similar to what I used.
