saintsairforce
- 1
- Sep 20, 2005
Maidstone,
Hello,
The other day I noticed my car (91 laser, 2L, non-turbo, fwd, 4 speed) was having a hard time starting. At the time I suspected either the battery or the altenator. The fallowing day I went to start the car, and nothing. I had power inside and the head lights worked fine. So I pulled out my meter and tested the battery to be sure. 12 volts, good. Next I checked the haynes manual and fallowed ther method of testing. I final think that it is the starter. After spending a good half hour looking for it I found it. I tried running a jumper wire from the + terminal and then I touched the battery quickly to see if it would turn. nothing. I then pulled out my trusty hammer and gave the starter a few nice taps. I tried it and the car started up no problem. Today I'm noticing that the car is hard to start and am pretty sure I have to do something with the starter. I was thinking about pulling it out tonight and pulling it apart to clean up the contacts, and inspect bearings and such. I'm hoping this works. I called around for a replacement starter but they are pretty pricey here. Any tips for working on the start? Any thoughts on what the problem might be instead of the starter? Thanks for any replys.
Ricky
Ricky
