No-start problem
cj062989
56
May 20, 2009
North, New Jersey
I got the engine from a 95 automatic gsx and a fresh unaltered wiring harness with manual ecu for a 97 gst. The car will crank but not start. I also noticed that on the timing belt side of the automatic engine there are two plugs and only one plug from the wiring harness fits in there.... Could this be the problem??????
I'm having a similar problem . I got the engine from a 95 automatic gsx and a fresh unaltered wiring harness with manual ecu for a 97 gst. The car will crank but not start. I also noticed that on the timing belt side of the automatic engine there are two plugs and only one plug from the wiring harness fits in there.... Could this be the problem??????
the 95/95 motors have a cam and crank sensor both on the driver side of the engine and your harness is made for a 97 which has a crank sensor on the driver side and a cam sensor on the passanger side... thats your problem
you can do this
http://www.magnusmotorsports.com/tech/1gina2g.pdf
but you will need to swap to 97+ cams also or get a 97+ CAS and swap cams still
Black is correct as you are missing the sensor signal. Without the signals, the car won't start. The ECUs are the same otherwise.
RRE Instructions
The intake cam just needs to have the slot on the passengerside so the CAS can be inserted into it. Follow the instructions in the link or buy the harness. I think JNZ also carries it but not too positive on that.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
