stall problem
jeremy0203
Nov 6, 2004
cleveland, Ohio
ive had my car back home in the shop for like the past 3 months or more getting problems it has had fixed. the mechanic finally got everything fixed except its having one problem. he said when you run the car hard it will stall out while stopping. im wondering what all could possibly be things causing this and what i should look at when i go back home in a lil over a week so i can hopefully get that problem fixed
you mean after a hard run, you put it in neutral and the car will stall?
check youre base idle speed, also do an ohms test on the isc motor.
