SS oil supply line
lil corb
758
7
Sep 7, 2005
Woodbridge, Virginia
hello, I recently bought a FP SS oil line for my 1st gen, question is could I reuse the bolt the stock feed line comes from to the head to block off the head supply? or would I have to get a new bolt?
I'm on stock 14b would the oil line from oil filter housing be bad for it? too much pressure?
thanks
I would use the oil filter housing feed location. You can reuse the bolt, but not the crush washers for the head supply. If you feed the the filter housing, put a block off bolt in the head.
