2G SRS Light
antlip
175
Jun 8, 2005
browns mills, New Jersey
I took out my head unit yesterday and put it back in after checking the connections and now my srs light is on. Any chance I hit something and messed something up?
only thing i can think of is to check the connection to the passenger side airbag. all airbag wires should be red so follow any red wires and make sure connectors are secure. however, i believe to remove the srs light from the guage cluster it cannot be removed without the use of a srs diagnostic scanner (correct me if i'm wrong). hope that helps, good luck.
