spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
So here's the update: I went for a test drive finally, that lasted more than a couple minutes, and returned early yet again. I only got 8 miles on the engine
Was cruising along and I'm hearing a scrapping sound just like last time, but slightly louder. Also got fluctuating oil pressure levels that ultimately leveled out at 3/4 way up the gauge before I shut her down back in my garage. Is that a good sign of my oil sprocket/pump issue I had before that caused the rebuild? What made me return home though, was something came off and started flapping around under the hood. Turned out to be my A/C belt had come off the tensioner pulley. Guess I didn't tighten it enough. Easy fix there. Think it's time to stop with the late night maintenance. There's also some faint knocks coming from the cylinder 4 area inside the engine. That's what it sounds like to me anyway. So I am now, yet again, at the mercy of you guys and your ideas, experience, and speculations. Thanks
