2G High oil pressure
dsmaddict123
37
Apr 2, 2012
hainesport, New Jersey
randomly last week i started getting high oil pressure, i have an aftermarket and i was reading normal levels then it started getting to over 100 at 2.5k rpm. Now it does it all the time unless im driving for over 20 mins but then still gets to 100 at 4 rpms. im running 5w-30 and a kn filter just changed the oil today thinking it was that. no luck.:banghead: and also at idle when start up im at 60-70, when warm im at 25=30 when i was at 10 normally.
If your having high pressure from before it could be sender issue, if you added it recently. I have a aftermarket one too with a fresh build but its high but not that high, of course ive been using aftermarket ones for years and im used to it.
ive had the new gauge and sender for a little over a month now, thats how i seen i had normal preesure before.
