1G Sputters/Stumbles under boost
markdr7
80
Nov 14, 2008
Denver, Colorado
My 93 talon is having issues when I get into boost it starts to hesitate and stumble. If I keep on the boost, it will sometimes snap out of it and keep going. The car also has a very minor intermitent miss on idle. I did a boost leak test and I found out that the o-rings on the turbo were bad. I rebuilt the turbo and it still is having the same symptoms. Anyone else have an idea that I should try? By the.way the cars stock except for a 3" exhaust.
I did do another one and I didn't find an more leaks. That was my first guess also, but it turned up nothing.
I was thinking plugs and wires. I just wasn't to sure if it would have those symptoms. I guess I could give it a try though. It can't hurt.
It can be a number of things!
You could be getting insane amounts of knock and its pulling the timing!
You could be running too rich, or too lean.
Timing may be off!
Plugs and wires may be bad!
how much boost are you running?
And what are upgrades to you have?
I see you have a ported 14b and a MBC but nothing else to support high boost!
That a different car. The one in question I just recently purchased. It is stock except a 3" exhaust.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
