gsxAWDdsm692
- 780
- 2
- Apr 24, 2006
West Chester,
Pennsylvania
Lemme know what you guys think.
uhh, yea. It's time to pull the oil pan (well, the engine). I hope she went out with a bang!
Bearing soup...yum...
Wow, hello rod knock..
Ouch.
^ ahaha thats good.
Is it possible to change rod and main bearings on a gst without pulling the motor? Like just drop the oil pan? Isn't the crank toast too?
yes it's possible. ranger87 just did that with his rods and his mains about a week ago.
I have heard of that being done some several occations but, that sounds bad so im thinking the crank is toast, my car would stay on even at idle when that happened.
Sadly, yes, I would know all about spun bearings. I have my car running with about 100 miles on it now
No, you can't get to the main's without removing the crank (i.e., removing transmission). I would recommend pulling everything in one shot and then tearing down the short block for a look. Either way, you're going to need machining work. With a knock that loud, I suspect the crank to be no good (unless you want to cut it).
how could you tell if the crank was toast cause i bought a parts car that supposedly spun a bearing, but looked at the crank and i didn't feel any scores in it, and i was thinking of rebuilding it just as a spare motor. Also who can you tell when a bearing might be going out, like what might your motors symptoms be, or dose it just happen?
