Jaraxle
- 104
- 4
- Mar 8, 2003
Troy,
New York
This was the worst weekend ever. I took my 1999 GS-T with 42k on the clock to a dyno to be tuned. Mods are:
1.) 3" SS turbo-back
2.) Yonaka Bar/Plate FMIC
3.) Joe P MBC (set at 14psi)
4.) 1g bov
5.) Apexi filter
6.) AFC-II
7.) Mandrel upper piping
8.) boost/oil gauges
It was running PIG rich when they first ran it ( 9.0 @6700 ).
(is this normal for an almost stock car ?)
The tuning guys tried to lean it out a bit, doing one pull at a time.
As they removed fuel, power WENT DOWN. And they started to hear knock.
The leanest they got it was 10.6:1
They told me the engine needed the extra fuel to stay cooler, so they were going to undo their changes.
They did another pull and it knocked real bad at 5500 or so.
One last pull and the bearing gave.
This was all with 93 octane that I always get from the same station.
They never leaned it out bad.
Theories:
1.) Car overheated with FMIC blocking wussy fan.
2.) AFC-II knock wire was connected for DAY a week before. Could this of fried/damaged something ? Causing timing to be wrong ?
3.) After removing the AFC-II knock wire the knock wire to the ECU was soldered and taped up. Could this solder joint caused interference ?
4.) Rod bearing just wanted to go, and there was nothing I could do about it.
This car is babied with mobil 1 synthetic, and k&n oil filters.
I am the second owner, and all mods were done by me.
Any ideas would be appreciated.
I know I should have been logging timing.
When I connected an OBDII scanner, it wouldn't initialized/talk to the car for some reason.
Also, a day before I logged 2187hz on the AFC-II during a "fun run". Isn't this beyond what a T-25 should be capable of ?
Perhaps I have a bad airflow sensor ?
I have videos of a run right before it went pop. You can hear the engine "going bad". Hard to tell whether spark knock or rod knock from the bearing giving up.
Thanks in advance,
Jaraxle
4.) 1g bov
5.) Apexi filter
6.) AFC-II
Theories:
Thanks in advance,
Jaraxle
