General Speeduino TunerStudio settings, are they any good?
Alex40823
5+ Year Contributor
31
11
May 30, 2021
San Jose, California
Hey y'all, It's my first time setting up a speeduino board and messing around with tunerstudio, so I'm learning as I go, since this is all new to me.
I currently have these settings and engine turns on so that's good, it idles well enough that it doesn't die, drove around the block but that's about it. But I want you guys to recommend me on what to do, what to change, what are the rights and wrongs.
I haven't dyno'd it yet, my tuner just started doing his thing on the VE, AFR, Ign advance tables but that's about it.
It's a bonestock 1g 4g63t, 510cc yellow injectors, td05h 14b turbo.
These are the settings I have on tuner studio:
Some of these settings have either been modified or haven't been changed and that's what TunerStudio has loaded in.
Also to note the temperature are in Celsius and not in Freedom units. haha
Thanks everyone.
First, sorry this isn’t a solution post :cool:
But… You’re a bit of a pioneer with Speeduino on this forum. There haven’t been many posts at all from others, and the little help I’ve given was just from reading the Speeduino wiki.
The important thing is when you do find solutions that work, find a way to spread the knowledge (here:D)!! It will help others in the future who choose to go the Speeduino route.
There's a first for everything haha Anyway, I haven't found a solution for the Stepper motor IACV problem I have, but what I did was adjust the base rpm with the Throttle stopper on the the throttle body, other than that I got noting.
I've been trying to figure this out for ever! What was your trigger setup for this?! I have the stock 1G DSM CAS (chopper wheel).
for the trigger degree I currently have it at -4 wasted spark
but the degree depends for each engine set up. when I was setting it up, I locked my trigger angle to 10* and used a timing light to see if it is firing at 10* and that's how I found -4* to be exactly 10*.
With the stock CAS disk, they're pretty low res, I have a bunch of my friends and speeduino groups telling me to get the Yoshifab High res disc to get a more accurate reading
and so I did, but I haven't installed it yet.
The one on the left is the stock 1g CAS disc and the one on the right is the Yoshifab High res disk.
It would be nice to run that disk, but I only have the chopper wheel setup, I don't think I would be able to run the optical disk in that CAS. If you know where I could acquire an optical setup that would be fantastic! Do you know if the green top vs the black top CAS's from 1G's came in optical vs chopper?
That's the difference between the green top and black top, optical vs magnetic. There is also a sub-group of the green top for the 90MY and 91-92MY where the 90 version has a pigtail and the later has a connector on the CAS like the even later black top version.
