2G Speedometer issue
Check your connection at the trans. Does it change or improve if you make a hard turn? Fwd or awd?
AWD, it hasn’t happened long enough for me to try those things. I was going straight on the highway, but I believe I did pass over the bridge right before it happened. The bridge is a pretty good bump so maybe it is a loose connection. I’ll do some research and check that out. Thanks for the help so far
