Spec Stage 3 Clutch, Fidanza Flywheel, and OEM vs SPEC TOB
I just finally got my new SPEC stage 3 clutch today, along with my Fidanza 8 lb flywheel, and some oem parts. The SPEC clutch looks to be of great quality, and the fidanza flywheel looks amazing as expected. I'm taking it to the machine shop to make sure everything is balanced, flat, and to double check the step height on the flywheel. I have a good feeling about it as the Flywheel is CNC machined and the clutch already has counter weights on it as youll see in my pictures. Also i've included a comparison of the OEM throw out bearing vs the one that came with the spec kit. The oem looks a lot better.
Ill update after i get back from the machine shop and get it in and try it all out.
Well heres some pics.
Spec Pressure Plate
6-puck Clutch Disc
Close up of a puck on the clutch disc
Amazing looking fidanza flywheel, with the SFI certified sticker
Close up of machining on flywheel
Back of both TOBs OEM is on top
Close up of the front of the Spec tob
Close up of the front of the OEM tob
Sides of both TOBs OEM on top
A few oem things :)
Close up of pressure plate
Close up of counter weight on the pressure plate
Close ups of the dual sprung center hub on the disc
All of it resting together with oem tob and aligment tool
Well i got it checked out, step height is good, and it was all already balanced. I am very satisfied so far with both the clutch and flywheel. Be back soon after i get it in to update how it drives and how the install went.
Update: well i finally got them in(had to do the install in my garage laying on the ground) and got to drive it today after spending almost 5 hours trying to get my stupid hydraulic system bled out. even being a 6 puck its smooth as butter enaging, but feels very grippy. My engine revs quite a bit faster and easier now with the flywheel, and is also very smooth. pedal feel is just a hair stiffer than stock, but stock is pretty squishy anyway. ill update again after i get it all broke in and get to have some fun with it :)
I've got about 3000 miles on it now, and it chatters a tiny if you let it out below 1300 rpm, but is smooth and consistent otherwise. Did my first launch the other night (awd) and it gripped rediculously good, not a sign of slipping. I'm definitely satisfied with the clutch and flywheel. They both perform amazingly and are very streetable. I would recommend these to anyone who is considering or who needs a new clutch. Spec stage 3 is cheaper than ACT, grabs just as good if not better and i havent seen a single report of them failing and breaking to pieces like I keep hearing ACT's do.
