spark plugs pics
Pre-ignition or something in the cylinder. What heat range plugs are they? If they are too hot of a plug this can happen. It can also happen from the ignition timing being too advanced or too lean of a mixure.
whoa that's detonation
I don't trust NGK iridiums either
Injector cleaner isn't going to help you quick enough... but for future reference, Seafoam will work in moderation... will cause your injectors to leak with over use... Everything else is bullsh:t IMO
Just don't go using Seafoam to fix this problem
could be a lot of things
you can have your injectors cleaned for the same price as having them tested... they clean them, and while in the process they test the flow... they'll come back and tell you if it needs replacing
