Spark Plug question...
gsx 1
Oct 31, 2010
big bear, California
I need to buy some new spark plugs but im having trouble finding the rite ones. I have been lookin for NGK BPR6ES but i can only seem to find BPR6EKN for some reason. Will these work as well or should i keep lookin?
EKN's will work even though they are more expensive than the stock ES plugs. Use them until it's time for another change and by then you should be able to find the ES plugs.
(TIP: check with lawn mower repair shops that services Honda lawn equipment. Honda motors also uses the BPR6ES plug and these places do stock this NGK plug specific for Honda lawn equipment)
-DSM
Here is a very informative post from Brian:
B=thread diameter (14mm)
P=projected insulator
R=resistor type
6=heat range
E=thread reach (19mm or 3/4")
S=Standard 2.5mmø center electrode
The other ones have:
K=2-Ground electrodes
N=Special Side electrode
As for which to use, either will be fine. The 'ES plugs are what most people run (some run unprojected plugs - no P in the part number).
Here is the link to the ones you want, BPR6ES at Auto Zone. Like Gravedigger said, the part number is 7131.
Hope this helps!
