Rice Over Wheat
- 1,959
- 5
- Jan 24, 2004
Winter Park,
Florida
Battery volts drop to 11.6 if DSMlink has fans set to run all the time. Shut them off while in key A/C and shoots back up to 13.1. This has been caused by running a huge SPAL 1650 main fan which required a 30 amp relay. My other fan is a SPAL 810 slimline and draws twice the amps of a stock a/c fan. This is causing me to have starting problems if my fans are set to run all the time. This is on a Optima yellow top!! Before starting the car if my volts sink below 11.9 my turbo timer starts flashing in warning. I need more battery capacity or something.
I thought about running two batteries in series but that is way too much weight especially when you have to run the same size and model. Anyone know a solution for this, like maybe those capacitors that people with serious sound systems use? Any ideas?
My accessories running off the battery:
30 amp SPAL, 20 amp SPAL, wideband, RMT manumatic, aftermarket sound system, radar detector, meth injection kit, turbo timer, indiglo gauges, viper alarm
Damn!
