Spacer on elimination kit can you use with 2g
garputo2
99
Jan 17, 2010
Walla Walla, Washington
I have the 2 g with the crank angle sensor when you install the spacer and then the sensing trigger plate then the sproket will this mess up the sensing? Is the spacer only for 1g? i am thinking it will be okay but wanna make sure or should you use the sproket without the belt????
