sometimes when hes revving down, like pulling up to a light, it stalls
sickal
Oct 23, 2007
Yorktown Heights, New York
hey guys
i found a guy with a DSM willing to trade for my motorcycle...
its a 1995 talon TSI (he has a bunch of mods including a 6-bolt motor swap, AFC, 550cc injectors, tuned, 20g turbo, (20 psi))
he said it runs good, and the new motor has about 20k miles on it, but the body has 150k...
he said the ONLY thing is that sometimes when hes revving down, like pulling up to a light, it stalls....
could this be a big problem? i dont wanna buy somethin that might be a mistake...any info is appreciated.
thanks guys.
Yes, I do have an ACT Lightened Flywheel, but havent put the ACT Clutch in yet ( long story why i didnt put both in the same time) could that be wats doing it, because like i said, it ONLY does it SOMETIMES when i go from high rps and just drop it on neutral, i would go so far to say it does it like, 1/10 times? Doesnt do it often but when it does its just annoying to have to tap the gas for RPMs to raise up? Ill try my idle as i believe its a bit low, isnt our idle supposed to be like a lil above the 900rpm? mine is below that, almost around 800rpms?
Well thats the exact same thing that happened with me and my fidanza flywheel. Easy fix.... next time you test drive the car keep it in gear until about 1200 RPMS before pushing the clutch in. The RPMS should be low enough that the ISC will catch and save it from stalling. Also I needed to turn my BISS screw up to about 1100 RPMS and I have had no problems since I did that last week Tuesday. Hopefully that works for ya. Good Luck!
