Sometimes spark, sometimes no spark
Nate_dogg
47
Jun 2, 2006
Wichita, Kansas
About 3 months ago I had a spark issue, I replaced the CAS and that seemed to fix my problem. The car has been sitting a week since the last time I drove it, I went to drive it today and again no spark. So sometimes it will get spark, and sometimes it won’t. Has anyone ever encountered this?
AEM computer
Stock coil pack
Thanks a lot
Nathan
look into some new coils. they can even test fine but still not work correctly. are you still using the power transistor? i don't believe they would act intermittent, either work or not.
Thanks for your fast responses on my problem. I have now checked and changed the coil and the PT with no affect, then I did an ohm test on wires from the Pt to the computer, and they checked out good...then I put everything back together and it started right up. I am thinking my connector to my ECU is the culprit, since that was the last connector I messed with before it started up.
Thanks again
Not trying to be a dick, but have you checked your plugs and wires? How new/old are they? Have you checked to make sure the wires aren't nicked or anything?
If one of them is nicked, would that cause no spark in the others?
