Ceddy
- 847
- 41
- May 10, 2006
Reading,
Pennsylvania
If you are swapping your ecu in and out a lot, you may pulled a wire out of the harness a little. I had a problem with the throttle position wire, when I went over bump the wire would move making the ecu read 100% throttle, dumping fuel and making it bog and stall. Took me a week to figure out what was going on.
See if any readings are weird with a logger.
