Talek
- 418
- 0
- Oct 3, 2002
Iowa City,
Iowa
My brother has a 97 TSi with I think a dejontool uicp and an hks bov, if I remember correctly. The car only has 34k miles. I've been driving it recently, and noticed some hesitation when boosting ~10lbs merging onto the interstate a couple days ago. Since then I can't push more than a couple lbs before it bogs and makes a low warbling sound, the car vibrates slightly when it happens. I tested it for leaks and found several noticable ones on the UICP, so I adjusted the couplers and tightened them, I think they're fixed now. But, the problem persists, and the car is only pulling ~12-16hg vacuum at idle. (It does have a faulty idle control actuator, so I take odd stuff at idle with a grain of salt).
I know the TB gasket is leaking, soapy water foams on the sides, but if this is a leak it would have to be a pretty serious one to bog like it does, right?
Basically I just wanna know if this is a leak or not so I know where to focus my attention, and hopefully I didn't break anything serious.
