Some Logs
destruckeclipse
645
3
May 23, 2004
San Diego, California
I finally got my pocketlogger in so I did a few pulls to see how it is running. From what I see I might be getting a little knock, and running rich / lean in a few areas. Please point out anything you think I should adjust.
My setup when logs were done:
Big16G @ 15 psi, fmic, stock 450cc injectors, no afc(it's not installed yet).
This is a 3rd - 4th pull.
Code:
<table x:str border=0 cellpadding=0 cellspacing=0 width=278 style='border-collapse:
 collapse;table-layout:fixed;width:209pt'>
 <col class=xl24 width=64 span=3 style='width:48pt'>
 <col class=xl24 width=86 style='mso-width-source:userset;mso-width-alt:3145;
 width:65pt'>
 <tr height=17 style='height:12.75pt'>
  <td height=17 class=xl24 width=64 style='height:12.75pt;width:48pt'>Time</td>
  <td class=xl24 width=64 style='width:48pt'>RPM</td>
  <td class=xl24 width=64 style='width:48pt'>Timing</td>
  <td class=xl24 width=86 style='width:65pt'>O2 1 Bank 1</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="6.0185185185185185E-6">00:00.5</td>
  <td class=xl24 x:num>1948</td>
  <td class=xl24 x:num>26</td>
  <td class=xl24 x:num>0.38</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="1.1921296296296297E-5">00:01.0</td>
  <td class=xl24 x:num>2080</td>
  <td class=xl24 x:num>27</td>
  <td class=xl24 x:num>0.5</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="2.2106481481481483E-5">00:01.9</td>
  <td class=xl24 x:num>2300</td>
  <td class=xl24 x:num>28</td>
  <td class=xl24 x:num>0.34</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="2.8125000000000003E-5">00:02.4</td>
  <td class=xl24 x:num>2428</td>
  <td class=xl24 x:num>29</td>
  <td class=xl24 x:num>0.76</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="3.7962962962962964E-5">00:03.3</td>
  <td class=xl24 x:num>2684</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="4.386574074074074E-5">00:03.8</td>
  <td class=xl24 x:num>2912</td>
  <td class=xl24 x:num>23</td>
  <td class=xl24 x:num>0.82</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="4.9768518518518522E-5">00:04.3</td>
  <td class=xl24 x:num>3196</td>
  <td class=xl24 x:num>20</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="5.983796296296296E-5">00:05.2</td>
  <td class=xl24 x:num>3772</td>
  <td class=xl24 x:num>16</td>
  <td class=xl24 x:num>0.92</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="6.5856481481481476E-5">00:05.7</td>
  <td class=xl24 x:num>4204</td>
  <td class=xl24 x:num>10</td>
  <td class=xl24 x:num>0.94</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="7.5810185185185174E-5">00:06.6</td>
  <td class=xl24 x:num>4992</td>
  <td class=xl24 x:num>8</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="8.1828703703703696E-5">00:07.1</td>
  <td class=xl24 x:num>5540</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="8.8078703703703699E-5">00:07.6</td>
  <td class=xl24 x:num>6028</td>
  <td class=xl24 x:num>13</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="9.7916666666666671E-5">00:08.5</td>
  <td class=xl24 x:num>6760</td>
  <td class=xl24 x:num>15</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="1.1157407407407409E-4">00:09.6</td>
  <td class=xl24 x:num>4876</td>
  <td class=xl24 x:num>18</td>
  <td class=xl24 x:num>0.88</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="1.1747685185185185E-4">00:10.1</td>
  <td class=xl24 x:num>3732</td>
  <td class=xl24 x:num>35</td>
  <td class=xl24 x:num>0.52</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="1.236111111111111E-4">00:10.7</td>
  <td class=xl24 x:num>2680</td>
  <td class=xl24 x:num>0.02</td>
 </tr>
  <td height=17 class=xl25 style='height:12.75pt' x:num="1.2951388888888889E-4">00:11.2</td>
  <td class=xl24 x:num>1744</td>
  <td class=xl24 x:num>22</td>
  <td class=xl24 x:num>0</td>
 </tr>
</table>
Looks to me that you are getting knock from 4000-5500 rpms. As you can see your timing has been pulled right there. I would start buy adding some fuel there when you get the safc installed.
Your timing should have more of a curve than that. Should start lower and gradually go up. An AFC will be able to help with that midrange problem but can only be adjust for every 500 rpm or so but for the most part it will smooth it out.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
