need some advice on logs
wishful_laser
242
Nov 25, 2003
springtown, Texas
my problem is that on my afc its about -3 all the way across on the hi throttle side to get rid of knock and even then it all doesnt go away. but if i run it leaner taking out fuel my car stutters and bogs when i get up into the 4000 rpm range. my o2 readings are right at .94. it is a 1g. i have all my fuel mods with the gm maft blow throught setup and im running 750s with an afpr, and a 255hlp. i have my maft setup for 700 cc injectors cause my low trim is pegged at 118% and wont move. the manual says to richen up the entire fuel curve set it to a lower injector than what you have. i need to know how to get rid of my knock without having my car stuttering and bogging. n e ideas would be appreciated.
how about telling us what turbo, what intercooler, and how much boost? : :rolleyes:
im still on the stock turbo and intercooler. my boost is set at about 17. sometimes it goes to 19-20. but i do have all my fuel mods and the afpr set at 38psi
believe it or not i actually got those 750s cheaper than a used set of 550s. that and the fact that i will be getting the fp 3065 soon. saving the funds for it right now. that and my fmic. either or. i would put my stockers back in but i think i will probablly get fuel cut and i really dont remember where i put them. n e ideas as to what my car is doing? i add fuel to get rid of knock but at the same time if i add to much fuel my car bogs and stutters sometimes.
