Solid Motor Mount Install
TeeWX98GST
111
Jan 13, 2008
Cresco, Iowa
Well, i got my rear solid motor mount installed and on the car, but my front one is being a pill. If I bolt it to the chassis and go to do the hole, the bracket won't line up unless I lift the engine (well, duh :p). But anyways, I cannot find a way to lift the engine to meet the bracket this way as the engine will always list one way because there is no way to get a jack on the center of the engine because thats where the crossmember is. I have thuoght about installing the bolt thruogh the bracket on the engine first by jacking up the trans and putting it through, and then lowering it down and installing the chassis bolts last, anyone think this will work? Or does anyone have a better idea on how to do this?
