jrdrew5
- 508
- 1
- Oct 14, 2009
jacksonville,
Florida
Ok so i went to my local shop were i do all my work to my car, i was replacing the collant temp sensor cause i thought my guages was off sometimes car overheats a bit, no bit problem right, get to it strip it with everything i got all the way to a impact even heated up wont come out.the previous owner soaked it in rtv so im probaly gonna get a whole new housing,
anyways decided to put it all back toghter after i took the housing off to get sensor out and FAILED so i had to drive home so put it all back toghther crank the car up,
It cranks One TIME runs for a sec i hear some wierd clicks and ticking then it dies.
ecu throws no codes even when it threw 2 codes before
now we can bypass clutch switch and ignition switch and the car will turn over and over but no fire, we checked injector voltage,battery,spark, i belive we checked fuel pressure,
u can turn the car on push pedal to the floor turn the key and nothing happens at all no turnover no nothing just a click from the starter relay.
so my main question is what ecu will fit plug and play into my car and how much and i looking at i do wanna go with dsmlink so time in the future after im employed (not now) so what ecu do i need?
Bump
BUMP ### help asap!
BUMP need help asap yal!
