i think my turbo is gone
nick
154
Feb 13, 2006
Edmonton, AB, Canada
i guys..i think i just bast my turbo.when was coming out from the parking lot i rev to 5k and my bost went up to 10 psi and i rev it again my bost went only on 5 psi and the car wont run good ..if there is no bost it run ok,but as soon as there is bost it runs like there a wall in fron of you..pls.help..thanks guys
does the turbo spin?
if you actually did a boost leak test and you actually have no shaft play then theres no reason at all for your car to not boost. It must be possesed so you'll need to do an exorcism ROFL
How high did you pressurize it, were you using a compressor or a tank, how long did it hold boost?
i think u might have had a lil bit of boost creep maybe and at rev your car shouldnt hit 10 psi any ways if u reved it that high to make 10 psi u probably did a bad nono!
