small/big 16g question
Patience grasshopper, it's late sunday night, and there's not a lot of people posting... as far as your question goes, I have no idea, but maybe if you posted some pics of the housing, the casting numbers, and mesurements of the different ports, you would get a better answer... just a thought.
98turbo said:
Hey, I have a turbo and I'm trying to figure out if it's the big or small 16g. The exhaust housing is ported so I can't tell that way.
the turbine housings are the same between the big and small. the only difference is in the compressor wheel if I recall.
Obviously if you take the comp housing off and measure the wheel you can tell what turbo you have. The other way is they have a different number stamped on the comp housing, but I can't remember which one is which.
Bumping threads is not allowed on DSMTuners.com and if you take a picture it would be much easier to help you know what turbo you have.
s16g has a very very small turbo inlet. b16g and evo3 16g are much bigger... take a look at the "turbo pictures" thread in the hangout and look to compare.
