small 16g
If you are looking to rebuild it and there is no wheel damage, pick up a mhi rebuild kit for around $100. There is a great writeup on rebuilding mhi turbos by jusmx141 on this forum.
The exhaust housing is only connected to the compressor housing (the part I sold you) by a clamp that is the same size as the one found on your 14b. Also, the bolts holding your 02 housing to the turbine housing on the 14b will fit the 16g housing. Basically, everything is interchangeable (i.e. wastegate actuator, bolts, turbine housing, etc.)
