Slave Cylinder....I think
noyorol_1
114
Sep 12, 2003
Williamsburg,
Well my clutch resivor is no holding fluid at all.Now I can pull over put some in and be ok for about 15 miles or so then it gets stuck.Anway how hard is it to change a slave cylinder anyone know
It's not hard at ALL. However, you should find the problem, before you start replacing stuff. Might as well get it the first time, right? :thumb:
Find the leak, and go from there. If it's a cracked slave cylinder hose, or leaking slave, it'll leave a spot on the driveway and you'll have drips off the slave. If it's the master, your carpet will be wet.
http://www.plymouthlaser.com/masterc.htm
http://www.plymouthlaser.com/slave2.htm
Either way, replace the slave cylinder tubing with the braided piece from RRE and discard that bizarred piece of waterpipe between the piping on the fenderwell and the slave.
http://ca.dsm.org/FAQ/2g-clutch-fcu.html
http://www.roadraceengineering.com/instructions/2gclutchlineinstructions.htm
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
