2G Slack in my timing belt
Deuce of Spades
79
Apr 14, 2008
El Paso, Texas
I checked in my chiltons and haynes manuals but i havent quite gotten an answer.
Today i changed my valve cover gasket and i noticed that there is slack in my timing belt in the area between the cam gears. Its not a crazy amount but i can push it down about 1/8 to 1/4 inch or so. Im not sure if my car a jumped timing at some point or if this is normal. The car idles and runs fine and has never given me any reason to think the timing is off. Is there supposed to be slack and if so how much?
There should be no slack. It should be relatively tight. I'd be willing to bet that it is tensioned incorrectly.
If the tensioner is good, and properly tensioned than there will be no slack, there will be a bit of deflection, but no real slack.
Truthfully ive own the car for 2 years and im not sure when the timing belt was done. It sat for a year while i was deployed. Everything looked in great shape when i bought it, but i think i should replace it anyway. Who knows when the last time its been done.
I just had my buddy come over with his gst and im gonna compare.
Either the 1/4" deflection when you press on it inbetween two pulleys, or you can twist the belt a quarter turn between the two pulleys and it won't go any farther, is what you want.
You gotta have that deflection for toothed belt setups, or the belt will whine horribly and can even break.
-DSM
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
