simple tech question
95awdboostin
Feb 3, 2009
st louis, Missouri
I have a stock 95 gsx automatic.I was wondering if it wwould be safe to put my manual turboXs boost controller on it,and just turn it up 2 pounds.Also I want to get a little more power 10 mayber 15 hp with some kinda ecu or fuel management system of some sort,because I want it to be quiet no intake or exhaust.What would be a good idea for a little power with some kind of engine management system to go along with my boost controller only turned up to 14lbs
First off before you do anything i strongly recommend you have your maintenance done. After all is said and done, you can safely turn the boost up to 15, don't forget to buy an aftermarket boost gauge if you haven't already done so as the stock boost gauge isn't accurate. Also a few ideas that you could do to work around your stock setup is : port exhaust manifold, port o2 housing. We DSM'ers don't bench race, but a logger wouldn't be necessary at this point if you wish to stay/sound stock.
