siezed or broken center Diff, or rear?
Status
Not open for further replies.
Drift_SM
772
5
Jul 28, 2005
Titusville, Florida
I'M not sure if i have a seized/broken center or rear differential....but i know something is wrong because my tires dint slip when i take a 90 degree corner (the inner wheel screeches in a pulsating manor).
Is it safe to drive the car like this? Or will it completely destroy my transmission and or drivetrain?
i want to fix it but i need to do some more research....PLEASE GUYS HELP ME!
any suggestions on fixes and ideas ....any info? please!
On your problem if your unsure of what it is then you shoudl consider taking it to a shop and seeing what your told about it. Or just simply drain the fluid in the rear diff. and see if it has alot of metal shavings in it, if it does you could be in a world of hurt (well your transfer case could be).
Either way go get it looked at.
Your thread is closed because you obivously didn't read the rules of the forum when you signed up and posted this thread.
No Bumping Closed.
Please research your question also under our drivetrain sub-forum or possibly consider searching through those forums.
Status
