edshred
- 0
- Jun 6, 2005
McQueeney,
Texas
I have been shredding belts for the last month. What did I change that is making this happen?
Well today I spend several hours reading threads on forums and I appear to have a solution to my issue.
It appears that the water pump pulley has been removed and replaced backwards. In the last month I had to take my car to AAmco in Round Rock, Texas to replace the clutch. 80 miles away from home and I had the money for someone else to work on the car.
Then I lost the ECU because the crank position sensor went south. I had the eclipse towed to the Mitsubishi dealer in Schertz, Texas. They had it for 2 weeks. Because I did not want to buy an OEM ECU. They ended up cutting me a deal and I had them replace the ECU.
I did not remove the pulley so one of these shops removed it and put it on backwards. I have attached a photo for the comparison. At least 1 inch off center. That is why I am shredding belts. They sqweak real bad before they shred.
My final question is: What is the proper way to put the water pump pulley back on. It is a real B to line up 2 pulleys to a water pump housing that moves?
<a href="http://picasaweb.google.com/eschulz1010/AutoRepair/photo#5200055790756583490"><img src="http://lh5.ggpht.com/eschulz1010/SCpPMMxCWEI/AAAAAAAAA08/8x1SQPPb_Aw/s144/DSC00870.JPG" /></a>
