should i get these injectors
I dont buy anything used just because you can run into problems with them not flowing correctly but I am sure you can have them flow tested and cleaned for cheap. Here is an article that I help make and I learned a few things about fuel setups here. should be helpful.
http://www.dsmtuners.com/forums/bolt-tech/410388-injector-pump-sizing-questions.html
* make sure you get new upper and lower seals when you pick some up too*
I have baught a set ove PTE injectos off of "evo" on ebay and had no problems. But I dont know if evo 1, 3, or whatever gen will work. I just know my set worked. From what Ive read they will. That will be a good set. But you could wait and find a set on here.
Yes they are a direct fit, Looks like you will need to pick up some seals though and get them compensated for on your eprom.
