what suspension should i get
3keclipse
May 10, 2010
Ks, Kansas
hey guys i got a question im new to this and i dont know where to go for this question i have a 97 eclipse spyder turbo and everything but my intercooler is really close to the ground my girl drives the car and the street here are all messed up and lots of pot holes and stuff. my car is really low and the intercooler pipe is less then proboly 2 inches off the ground my choices were to ither get a new intercoolerand have it re routed or to change the suspension cause the back of the car was lowered but the front looks even lower. should i just go back to factory springs or what do i need to fix this problem ill get pics up when it stops raining outside thanks guys if you can help me.
Yes, the stock springs should raise it up enough to clear most things but nothing will make it pot hole proof short of raising it up. You'll still have to stop short on parking spots with concrete stops or you'll scrape the bottom of your bumper. A friend of mine had a stock 99 gsx and still had some issues. It's a low slung sports car not a truck after all.
Yes the stock springs should fix the problem. Or you can get some adjustable springs and raise them up 2 or 3 inches.
