shop says i spun a bearing?
RGdsmNewb
223
Feb 19, 2006
Edmonton,
Apparently after getting my timing belt changed and all new wires etc etc, they think i have a tranny problem. There's this scraping noise that i get that's fairly minor and usually only occurs under WOT and significantly more when im in second gear. Is this a ridiculously expensive fix if i do have a spun bearing..... or is the shop off, sorry wish i knew more about these cars. I'm freakin out cause i've spent alot of money already and know that she also needs a new battery
did they say "throw out bearing"? it's a cheap little part that sounds like what you describe, however, the labor for it involves taking the tranny off which is usually expensive for any shop to do.
If it's a spun bearing, it would be in the block, specifically on the rod... If its the throwout bearing, it is the bearing infront of the shift fork, very cheap part but semi labor intensive like project15 stated. Involved literally taking the tranny out of the car to install a new one.
On a cold start you can hear my TOB, sounds nasty:cry: try listening to it when idling. Listen for it and right when u hear it push the clutch, if it goes away its most likely your TOB.:thumb:
