shifter
rightaway
70
Nov 11, 2003
hi, my car is really hard to get into first gear and reverse. i already changed my trans fluid about 2k ago. i have a rre short shifter in it. do you think new shifter bushing would help?
is it not letting you into first and reverse because of bad clutch engagement? If so check clutch master cylinder as well as the slave cyl.
Check for leaks at mc and sc then bleed the system. You can also adjust the mc to bring the engagement a little higer. If the engagement changes again after you adjust it, don't adjust it anymore the problem is somewhere else.
some one once told me that there were no syncros for reverse. and usually when ur syncros are going cant you hear them? it makes a wining sound.
is there a write up or some where i can go to find out how to bleed the mc? bc i cant drive the car this this. you have to push so hard just to get it in gear.
http://www.plymouthlaser.com/slave2.htm
It's for slave cylnder replacement but it shows how to bleed your clutch PROPERLY at the end of the article.
http://mywebpages.comcast.net/njdsm2/clutch.html
That's for the clutch adjustment. Wasn't sure what you meant by "bleed the mc". Both links are for 1g but same idea.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
