Shifter plate bolts broken
xveganxcowboyx
1,525
23
May 15, 2005
St. Paul, Minnesota
The same day I added bearings on the tranny end of my shift cables, I tried to replace the bushings holding the shifter plate down. I started loosening one up only to snap it off inside the hole. Damn. I was more careful with the second and when I felt it start to resist I added oil and backed it in and out quite a few times. It still felt like it would twist in half so I gave up and tightened my remaining 3 back down.
I assume I'll have to use an extractor on the broken one (assuming it will come out), but does anyone have any ideas for getting the remaining ones out? I will be putting in better tranny fluid when i do my clutch next week and would like to do this to compliment the new setup.
for the 1g person, try drilling them out and extracting them. they shouldn't be that hard of a bolt. if that doesn't work then you can helicoil them.
for the 2g question, they should either be m8x1.25 or m10x1.25. m8 has a 12mm head, and m10 has a 14mm head.v they get torqued to 9 lb-ft.
Thank you sir.:thumb:
I got the bolt out with a drill bit and pliers.
Now I just need to get to the store and get a replacment bolt with the specs you listed.
