starter plate bolts
loba
117
Jan 7, 2009
Corvallis, Oregon
Can someone tell me how the starter plate bolts on? I know there are two bolts on either side of the transmission, two bolts on top, and two bolts from the starter. But there are two additional holes. Do those bolt to the block behind the flywheel?
Thanks
Yes, the starter plate is held to the block with 2 bolts through the little holes. It goes behind the flywheel.
Damn. Have to pull the tranny to replace what the previous idiot never installed. Standard height bolts or are the stubby heads to prevent hitting the flywheel?
Awesome. And then it's M6X1X30 or so for the outer bolts right (starter plate to transmission)?
You sure?
